Sub Woofer
I have a Ct290 sound bar and sub woofer i was thinking of up grading the sound bar can any one confirm if any sony soundbars will connect up to sony sub woofers via blue tooth?.
2 REPLIES 2
Anonymous
Not applicable
Hi there,
Hopefully a community member will be able to help.
Best wishes,
M
Win_88
Specialist
Hi @I-want-my-Mtv
If you're planning to upgrade your audio system for a new one that also has a wireless subwoofer, you can find the available options here.
Note that it's not possible to mix and match sound bars with subwoofers. So you can't connect yours to a different soundbar.
Win_88
