Connecting a Sony sub
MarkyT288
Hi guys simple question for you , I have purchased a Sony STR-DH810 Amp but my sub has a Sony plug on the end and my amp has the sub phono socket ? Is there anything I can do to connect the two together ? All help greatly appreciated.
Regards Mark
4 REPLIES 4
Sean_Mc
Hi Mark,
Welcome to the Sony Community.
I'll try and find an answer, in the meantime perhaps someone else in the community may know the answer.
Best wishes,
Sean Mc
Win_88
Specialist
Hi Marky,
It would help if you tell us which Subwoofer you have or at least what it the connector that it has so that we can find a possible answer. Maybe even take a picture of it :slight_smile:
Win_88
MarkyT288
Pls find attached pics for clarification,I'm at a loss as to weather I can connect the sub to the amp by maybe cutting off the plug and attaching a connector that will connect into the amp ? Sub and connectorSub and connectorBack of ampBack of ampIMG_2712.JPG
batee5
Specialist
Hi MarkyT288,
It seems like you're trying to use a subwoofer that was supplied with a home theatre system with this AV receiver which I don't think is possible as different devices require different connections and specs.
I'd recommend getting a subwoofer that's specifically made to work with AV receivers.
Regards,
Batee5
