- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
April 2024
April 2024
Hi here
Basically on my Sony RCD W100 drive A will only open with a cd it in if it’s empty you can hear the motor but it will not open unless you press the draw down slightly on the top of the front plate then it opens no problem. Any ideas thanks in advance
1 ACCEPTED SOLUTION
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
April 2024
April 2024
Belt was slipping replaced it with one I got from eBay problem gone
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
April 2024
