CMT-SBT20B headphone issue
bobladdie
New
Is there any way of using headphones with this system? Just had it as a Christmas present with the intention of quiet listening so its a bit useless.
3 REPLIES 3
Joe_Dohn
Specialist
According to the Manual (page 23), the system can't connect to Bluetooth speakers, which means it doesn't support Bluetooth transmission, only acts as a receiver for phones, laptops, etc.
joejoe66
New
Yea they don,t tell you that when buying it do they, no info about that on packaging, i have the same problem a hi fi that i cannot use head phones with so is practicaly useless to me, SHAME ON YOU SONY, wont buy your products or recommend them.
Anonymous
Not applicable
Hi Bobladdie,
According to the manual, this is not possible :(.
