Hello,
I have following TV model : Sony 48 "LED Smart TV KDL-48W605BBAE
it supports
| DVB | C / T2 / S2 |
Also it supports:
| Approved by Boxer | Yes |
| Approved by Com Hem | Yes |
| Approved by Canal Digital Kabel | Yes |
| Approved by Canal Digital Satellite | Yes |
But I still dont get default channels in my TV. I live in Sweden. Can someone please point me out some settings in my TV which I am missing?
i have a white cable at my home which I am putting in the back side of the TV (white slot)
can you please tell me what exactly are you asking?
Hi @ali.electro,
a white cable could be DVB-C or DVB-S (depending if you have a satellite dish on your house).
If you haven't done it yet, your TV needs to scan for channels first.
- Nic
i attached the pics
i have tried scanning . can try again.
i spoke to TV manager on phone and he mentioned somethin like DVB-T
Hi @ali.electro,
your TV does support DVB-T as well, yet the cable you connected is a DVB-C cable.
DVB-T means Terrestrial and requires an antenna connected to the TV as far as I am concerned.
- Nic
scanning does not seem to help 😞 football world cup is starting tomorrow I need to get this fixed :((
