My Sony Xperia x5 has a small amount of storage left. I have installed a sd card and it still shows limited storage. How do you transfer data to new sd card
Hi @Tomjones1, welcome to our forum!
You can transfer data to the SD card if you follow the instructions below.
If applications do not show up in the list of available content that can be transferred to the SD card, you will need to do it manually.
Let me know if that helps!
