problems with settings
SOLUCIONADO
AlanMartins
Visitante
1 SOLUÇÃO ACEITE
Soluções aceites
Jonas
Master
Hi @AlanMartins, sorry to hear about this.
I'm not quite sure that I understand what behaviour you are experiencing with the settings application, would it be possible for you to elaborate a bit? Is the application not starting as it should?
If that is the case, try restarting your device in safe mode and see if you are able to launch the application when downloaded applications aren't loaded.
Let us know how it goes!
Ver solução na publicação original
5 RESPOSTAS 5
Uliwooly
@AlanMartins
Are you using a taskiller? are you clearing the cache of any apps?
Uliwooly
@AlanMartins
AlanMartins
Visitante
I only use the option to clear the cache in the only storage configurations.
Uliwooly
@AlanMartins
And after you do so, that's when you encounter the issue right?
Jonas
Master
