My files are deleted.
SOLVED
blogger1
Hello.
I bought an Xperia E dual a couple of days ago. It's good enough but unfortunately It has a problem in fact. When I receive a file or stuff via Bluetooth It's OK, but after I turn it off then on, I see that my received files are whole gone, whether deleted or hidden I'm not able to find them again. Of course about music files' name are still in my playlist but when I click them they are not played
(better to mention that my Bluetooth receiving storage is my Internal-memory)
I hope u help me
1 ACCEPTED SOLUTION
blogger1
Ooooooooh I got it finally!!!
The problem is with my memory-card!!! When I write something on it (even in PC) it deletes after a while. And I can't clean before-existed files.
If anybody has a solustion to repair my memory-card, so much the better
6 REPLIES 6
Ashoksc19
Contributor
Have you seen your files in bluetooth?
Settings-Bluetooth-Press Menu- Show received files.
check first files are there or not and reply back.
blogger1
Their name is still there, but when I click on them this error appears : "No file(title)  the file doesn't exist"
blogger1
Very necessary! Answer please
Ashoksc19
Contributor
Weird issue.
Try to repair your phone with SUS or PCC. May be it can fix
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
blogger1
Vengence
Contributor
Just format it... Or It may be permanently damaged
