i cant hear my caller (sound quality very poor
SOLUCIONADO
228rod
Visitante
i just got my sony xperia e c1504 about 10 days ago
and the caller sound quality is so poor i can barly hear
them and it hasn't gotten better from day one,any ideas?:smileyconfused:
i have the the lastest updates a new sim card from t-mobile
jellybean 4.1.1
build# 11.3.a.2.23
model:c1504
it saays your phone already has the lastest available system updates.
everything else works great(i,e. sns..wifi,dlna,gps all work ok
just the caller sound quality.
1 SOLUÇÃO ACEITE
Soluções aceites
Cot88
Entusiasta
Try another SIM card (of another carrier)
Try if issue is the same using headphones
Try to force 2g net
Ver solução na publicação original
3 RESPOSTAS 3
Cot88
Entusiasta
Try to force 2g net
228rod
Visitante
thanks for the help but i seem to have other problems with
calling ; i made a call this morning but now it says
    (mobile network not available)
honestly i'm not sure if i'm using wifi or hotspot connection
which should i use in the setting? to make a call all the time with no issues?
i have service...i can get online ;use skype and google hangout but sometimes it just making
a simple phone call out; and incoming callthe same problem.
Cot88
Entusiasta
Do you mean a standard call or a VOIP call (that uses data connection or wifi)??
Do you have a red cross on the upper left side of the screen and/or 0 bars of signal?
Anyway go to
Settings>other>Mobile networks>Network operators>Set WCDMA(Preferred)/GSM
Settings>other>Mobile networks>Network operators: Set Select automatically
