Sony dsc hx99 camera
Mellb31.
New
Hi,
can anyone help me please , my camera won’t save pictures that I have taken as when I do playback there is nothing there ?
what am I doing wrong ?
thanks
1 REPLY 1
danardeng
Contributor
I think that you have this option active https://helpguide.sony.net/dsc/1820/v1/en/contents/TP0001850447.html
and you have a problem with your flash card.
Try to extract and reinsert the card. Be sure that it isn't protected https://www.sony.com/electronics/support/memory-cards-sd-cards/sf-g128t/articles/00067190
Do you had formatted inside the camera or outside (on a PC)?
Anyway, try to format again with the camera https://helpguide.sony.net/dsc/1820/v1/en/contents/TP0001827060.html
If you have still the issue, you have to chande the flash card with a new one.
If you have still the issue, try to fully charge the battery and initialize the camera https://helpguide.sony.net/dsc/1820/v1/en/contents/TP0001827069.html
If the issue is still present, probably there is a damage on the main board of the camera (flash card slot or some internal component)
