My phone has actually the release 29.0.B.1.55 installed.
When I check my phone for an update I get the message that I have the latest release installed.
The support Webpage says that the latest release is 29.1.B.0.87.
How can I get the latest version?
BR, Markus
Gelöst! Gehe zu Lösung.
Hi @Markus2,
Update availability varies between different regions so if you haven't received a notification about a new software update in your phone it may not be available in your region yet. As soon as the update is available you will should receive a notification informing you of it. You can also connect your phone to a PC and have any of our PC software search for new updates.
Thanks for letting us know!
