Xf9005 bright line above volume bar
profile.country.GR.title
Ben3os
Hello,
I am new to the forum and I would highly appreciate if you could help me with my -less than 2 months old- 65xf9005.I have noticed that when i increase or decrease the volume,15 to 20 cm above the bar, appears a bright line that highlights the hole area on the volume.Is it normal?I have already tried rebooting and factory reseting.I am attaching also photos of my problem.Any help or information will be highly appreciated.Thank you.
13 REPLIES 13
rooobb
Unfortunately I do not have a solution for you...I bought an OLED that does not have this behaviour
Ben3os
Sorry for the offtopic.Seems that updating to oreo has solved my problem BUT now when i do a black screen test via YouTube video there is some light blinking in the right down corner of the tv.Do you know what it might be?It hadn't done it until now.
rooobb
Do not know which effect you see...an example? Did it happen also in  normal viewing?
Ben3os
I have noticed it during a black screen test on a YouTube video.It is like in the bottom right corner some backlight trembling white light but with low volume.In normal viewing i have not still seen something since I haven't watched Tv from yesterday.This happened after my update to oreo.
