Videoplayer for Android TV
SOLVED
Realquante
Hi all,
I've got a Sony XF90 TV since a few months now and I'm using DS-Video to access the video's stored on my synology NAS. This runs pretty well but I didnt find a videoplayer that works well and doesnt cause any problems:
- Standard videoplayer: AC3 passthrough works well but it has no subtitles
- MX-player: tried everything but AC3 passthrough does not work at all
- VLC: same here, no AC3 passthrough
- KODI: own interface so no need for DS-video, it works awesome but Netflix stops working (starts 1/2 times and then I gotta reboot the TV)
I was hoping for BS player, but thats not in the Playstore.
Anyone else have this problem or knows of a good videoplayer that works?
Thanks,
Dirk
2 ACCEPTED SOLUTIONS
IT = Archos fa correttamente il Passthrough in DTS.
UK = Archos does the Passthrough correctly in DTS.
https://community.sony.it/t5/televisori/android-oreo-problema-audio-dts-non-funziona/m-p/2570692#M52...
5 REPLIES 5
Realquante
Hi Marino,
I'm gonna try this tonight! Thanks
Realquante
Archos work great!
DTS passthrough didnt work yet, but its not a big problem and maybe with some setting changes it will work.
Thanks!
Realquante
And DTS works as well, had to put passthrough in "mode 1" instead of mode 2 I had earlier.
Great videoplayer, hope that Netflix stays working OK :slight_smile:
