Morning all
Can Anyone Pease Please Please share with me a telephone number to ring Sony ??
I did call them Monday, now that telephone number wont work from my phone and if i try to use the Ai chatbot it only shows the previous input and wont let me start a new chat to get support.
Im frustrated and angry and feel like im being ignored and messed about.
Does anyone have a number?
Hi @graygerman Try putting 141 in front of the number.
https://services.sony.co.uk/supportmvc/en/Contact/Email?cat=televisions-projectors1&tab=Tips&act=cls
Thankyou its now sorted. must have been an issue their end.
Hiya! Do you happen to have the contact number? Every one i am trying i am unsuccessful!
Has anyone had a problem with an 8 year-old set that constantly buffers now that I have increased my Wi-Fi to 65 megabits. You tube, Netflix and web browser work perfectly so the problem is with the TV apps (I player, ITV player etc.) which I can find no way of updating. Connecting via Ethernet made no difference. Sony rep at a local store could only suggest that the software was no longer maintained.
Any ideas?
Hi @Castleman I suspect your Sony Rep is correct, like everything the latest Apps need more power/memory then old hardware can support. However, all is not lost. Why not buy a Roku or Fire TV stick and add on the latest hardware for about £30-40.
Hi @LightFoot, thank you for your prompt and helpful reply. What puzzles me is that I can use iPlayer etc. through the web browser without any buffering and use the apps via a mobile hotspot (12 mbs) but not using my fast and excellent power Wi-Fi.
It seems to me that an update to the TV player apps is called for. Once again, many thanks.
I’m having the same problem.
i think it is disgusting that they don’t have any working phone numbers.
i don’t think I will buy their products going forward
I agree I have been able to re install the apps for U, 5, and Great Player they are all working fine. It is just BBC ITV and 4. The channel 4 guy suggested uninstalling and re-installing the three apps.
i was moved from Plusnet to EE because I want to keep my landline.
neither company has been of any use!🤬🤬🤬
@hammiemhamilton wrote:i think it is disgusting that they don’t have any working phone numbers.
Hi @hammiemhamilton What happens when you phone the number? I just tried it, no problem but closed as after 6pm.
