- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony KD-55AF9 Home screen shortcuts disappearing
I have normal installed apps on my Android TV, (apps that can normally be added to the home screen without the use of Side Launcher), like FX file explorer or others, I add the shortcut to the home screen, and over night the shortcut disappears from home screen, and I have to add it again.
This issue did not occur before, it only started after I did total memory initialize couple of weeks ago.
I tried turning TV off and on, and rebooting the TV after adding them, the shortcuts stayed there, but still they disappeared overnight.
Very weird, and I don't feel i should need to replace the stock home screen launcher with another one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi khaeid2,
Welcome to the Community.
If you get in touch with Sony Support about this, they may be able to help.
Thanks,
Pascale
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try clearing cache and data of the launcher and set it up again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I actually did 2 things
1- Cleared cash and data for home launcher app
2- I have external SSD attached, used as internal memory extending, checked the location of apps installation, it seems icons belonging to apps installed on the SSD are disappearing, I moved them to internal, and will see
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ah....... so that expanded storage is still broken then. Since introduction in MM from 2016. And 8GB is still a thing for SONY in 2019.
