- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Trying to watch a film on Netflix accessed direct from my 65 inch OLED that I had delivered yesterday. Every 3 minutes or so the Sony sound bar cuts out: if I stop the film then restart then the sound returns. It is really impossible to watch the film. The sound bar is connected via optical cable Any ideas would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So whilst checking the cables I pushed them all in. And.... the problem seems to have gone away !
Thx a lot!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Tried a different optical cable? I guess your sound bar doesn't have hdmi.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It does. The installer used the optical link. He was trying to resolve sync issues. Do you think that will fix it? I get the problem only in Netflix whether accessing it via the tv or my virgin box
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello @Philahill,
please check if the optical lead is properly plugged in - I once had the same issue with my TV and it was simply not connected properly.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
All seems ok. I think I need to change it back to hdmi from Optical. Both the hdmi cable and the optical cable are plugged in. Just got to find out how to do it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That is so typical of optical cables, especially the cheaper ones. They never seem comfortable in their socket!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks. Not helped by crap John Lewis installers. They even plugged my headphones into the audio input....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So.... whilst it is better I now have the problem that the first word of sentences keeps being dropped off, almost like it takes time to restart even after a very short gap. I have a feeling I need a better optical cable. Any ideas?
