- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi all - thanks for all the informative information I have found on this community site.
I have recently purchased the above tv and I am using it with a (UK) BT Ultra HD package. The output of the box is 2160p50 and I have set it to 10 bit colour.
Generally speaking I am very happy with the telly but I am experiencing a bug which sounds similar to the "Screen Format: Full" issue reported on another thread.
After a period of watching TV (normally longer extended periods of say 2 hours), the picture starts to judder and the "Screen Format: Full" message flicks on and off. The only way to recover this is to switch the telly off and on again which seems to allow the telly to "resync". This problem happens *every* day when watching TV at least once.
It is not a problem with the BT box as when I switch that on and off the picture problem does not clear.
I have tried different 4K related settings on the telly / BT box but the problem still occurs. Has anyone else noticed this with the TV ?
Thanks,
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
is full factory reset required as usual?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No - Only if you experience issues afterwards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I note that many on the Sky Forums are now saying the juddering seems to have been fixed. Can others who were experiencing this problem confirm? As it would be nice to finally 'close/resolve' this thread off in a day or two.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hold off closing till the end of the month. Closing within such a short time frame,bearing in mind how long it's taken to get this far isn't really fair. It's only reasonable for everyone to have a prolonged period of in the field testing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have my t.v on since 09.30 this morning and it seems a solid upgrade.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's far too early to close this off. Given the randomness of the problem three weeks should be sufficient time to see whether the problem occurs again. We should leave this open until the beginning of December.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Noted : Will leave thread open for a while
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just a coinsidance???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well i updated my KD55X8599 this lunchtime and the juddering has stopped, however the audio drop out is still present. Fingers crossed this will be fixed in the next update then it will be perfect.
