KD55XG9509 recording
Zumo11
New
Hi,
Ihave just prurchased a KD55XG9509 telly and have a Humax HDR-1100S freesat box, they work fine together apart from the Bravia Sync doesn't work properly so I can't view the guide from the TV controller. However I have a USB drive that I can conenct to the USB REC port on the TV but was curios as there are 2 connectors for my Sattelite does that allow me to watch one programme and record another?
I know some model TV's don't but they also only have one input not dual.
THanks
Tags (2)
4 REPLIES 4
Sean_Mc
Hi there,
Welcome to the Sony Community.
I'm looking into this and will update the thread when I have an answer.
Best wishes,
Sean
MAIN is for Sat and SUB is for another Sat Antenna. The Sat Decoder is TWIN... For Play and Record (with limitations by CAM I think).
Happy with my product
Win_88
Specialist
Hi Zumo,
The TV has two satellite tuners, so it's possible to record from a channel and watch another simultaneously .
I found this some details about how Bravia Sync works on your TV in the Guide: https://helpguide.sony.net/tv/gaep2/v1/en/04-07_02.html
Win_88
