- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD49XF759 info bar stays on screen
On recordings and when switching channel info bar with hdmi source will not go, there is no option to turn off info bar, would really appreciate some help! Very annoying!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Edhall13
It looks like you have a KD-49XF7073 which explains why your screens don’t look familiar. Sorry to tell you but this is not an Android TV. In fact the software is Linux https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kd-49xf7073/specifications
Unfortunately I believe there is no work-a-round for Other TVs without degrading your audio experience. Setting the source audio to PCM or Normal would mean no audio format switching and therefore no Info banner appearing on each change.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes it does look more and more like that doesn’t it, I will be going back to the shop with this image and taking it up with them, thank you for your time, you’ve been very helpful!
- « Previous
- 1
- 2
- Next »
