IR Blaster controlling Sky+HD box
RESUELTAS
chrgray
Miembro
KD-65X8509C bought within the last week
I have the TV's IR Blaster setup to control a BSkyB Sky+HD box, and most controls work great.  However, the UP/DOWN/LEFT/RIGHT navigation buttons work, but always sends 3 occurrences of UP, DOWN, LEFT, or RIGHT instead of just one occurrence.
So, for example, when navigating the Sky+HD box list of recordings, pressing down skips down 3 recordings, making it impossible to select the recordings in-between.
Is there some way to update the IR blaster database to correctly only send 1 occurrence of LEFT, RIGHT, UP, or DOWN when that button is pressed?  Or is there any other solution to this problem, that will make the UP/DOWN/LEFT/RIGHT buttons behave correctly?
65 RESPUESTAS 65
ramman
Explorador
Has anybody else had success with this ?? I really don't want to do a factory reset unless I've got to
CUCO
big_black_dog
Explorador
Just tried factory reset and it fixes the sky remote issue (may also enable other functionality such as picture in picture & digital record).
The Sony remote works surprisingly well now (!) - latest s/w updates allow Sky to be the default input with the Sky channels in the Sony menu. Still trying this out..
Sent from my iPhone
Anonymous
No aplicable
Hi all
Are you saying that after a factory reset that this issue is finally fixed now?
Cheers
ramman
Explorador
That appears to be the suggestion , I'll give it a bash at the weekend
CUCO
nick.connor
Miembro
I am away from home at present but will try a factory reset when I get back. Thanks for the help.
nick.connor
Miembro
Confirm - now fixed after a factory reset.  Thanks again for the help.
Anonymous
No aplicable
Thanks guys.
Johnwithsony
Explorador
I have this problem now . Have done factory reset and to says up to date.
Buglenuge
Explorador
I too am having this problem. KD-49XE9005.  Factory reset hasn't helped
tarzan1977
Explorador
Hi. Wondering if you can help. Just bought a KD8005 and I am unable to access the Sky Planner/ Recorded programmes from the IR blaster.
Any suggestions would be welcome
Thanks
