I need Sony Original Product Boxes
OPGELOST
meszizsolt1982
Ontdekker
Hi there!
My name is Zsolt Meszaros. I bought around 2 years before 2 Sony products from Currys PC World,
a Sony Bravia KD65-A1 OLED 4K Android TV and a Sony HT-ST5000 Wireless Sound Bar with Subwoofer.
I told the delivery team, they can took away these product boxes. Now I just realised, that was a huge mistake.
If I need to moving out from my rented room, I can't transport these lovely products in safe without these original boxes and packaging.
I already asked Currys PC World and Team Knowhow, but they not stored any boxes...
Is it possible somehow, for a reasonable cost to ask Sony or the Sony packaging manufacture to remake these original product boxes for me with the original inside packaging if I will pay the cost?
Can they post these to my selected address if my enquiry solved?
If they can't make for these, how can I have these boxes? Have any ideas?
Thanks for the answers and time!
Regards
Zsolt Meszaros
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
5 ANTWOORDEN 5
Hi Zsolt,
I will check internally but frankly spoken I doubt that this will be possible.
I'll keep you updated.
Cheers
Peter
royabrown2
Held
Hi Zsolt,
Just received the information that this isn't possible from official side.
So maybe the option that @royabrown2 has posted is best for you.
Cheers
Peter
meszizsolt1982
Ontdekker
Hi Peter,
Thanks very much, you checked that for me.
Thanks for the time and the suggestion as well.
Take Care buddy 🙂
Regards
Zsolt
meszizsolt1982
Ontdekker
Hello mate
Thanks very much this solution.
I find a bit better in the past time, but I tried to get original boxes if possible.
I see, it isn't so I will give up, and choose the cardboard solution.
This one a bit better, because including all the packaging stuff too :
https://www.ebay.co.uk/itm/MEGA-TV-Removal-Box-Pack-ideal-for-LCDs-Artwork-Mirrors-Fragile-Screens/1...
