How to settings app Movie for 55XD8588
SOLVED
profile.country.RO.title
talex74
Hello,
it is possible to set image in Movie app (full, zoom....) because I show the picture movie to zoom.
 why video player to use but have DTS digital output?
Thank you.
1 ACCEPTED SOLUTION
Anonymous
Not applicable
Hi there
Marshmallow has not been released for 2015 and early 2016 TVs in the UK/EU Region.  See: HERE
In regards to audio output from apps - it is upto the individual app developers (i.e. VLC) to fix.
At the moment I would suggest using Kodi as it seems to work the best (in my opinion).
Cheers
3 REPLIES 3
Anonymous
Not applicable
Hi there
At current there is an issue with the video app, see:
https://community.sony.co.uk/t5/android-tv/android-tv-bugs-and-issues/m-p/2089584#M70
In regards to DTS - Im sorry but I do not understand your question?
Cheers
talex74
I updated my TV 55XD8588 but i dont have Android 6.0, why?
When playing the movie in the standard built in player Movie app the output sound  is indicated DTS however when playing with VLC the output sound is indicated Stereo. Wich player should i useto get DTS output
Thank you
Anonymous
Not applicable
Hi there
Cheers
