- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
July 2021
July 2021
Firmware update problem
Television Model KDL-32WD756 after downloading updated firmware onto USB stick TV says in cant find any recogniseable files to install. Tried numerous times to no avail. Help please.
5 REPLIES 5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
July 2021
July 2021
is it a compressed file that needs unpacking/extracted before being copied to the USB stick?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
July 2021
July 2021
Hi file is unzipped
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
July 2021
July 2021
Are you using the latest software version and did you double check that you do need it?
The "no applicable software version" message also comes up when you're already up to date.
Hope this helps!
- JD
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
July 2021
July 2021
Hi thanks will check version.
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
July 2021
July 2021
I had the same issue, solved by formatting the USB stick to FAT32 one, did you give it a try?
