Just bought the Ultra 4K TV and though I've activated it on the Sony Essentials site, so the "enhanced features" are now activated but I can't find the Netflix app anywhere. I'm trying to activate Netflix and, as per the FAQ, I've tried to locate Netflix in the Video section but it's not showing up? Even if I do a search, if I hit the Netflix button on the remote it comes up with a blue screen that says "Some features will be available after May 2015" etc. not happy with how difficult this seems to be...can someone shed some light????
Hi, please see this thread: https://community.sony.co.uk/t5/televisions/2015-bravia-android-tv-issues/td-p/1949079
Apparently there's a firmware update scheduled for Monday 15th June to fix this.
Cheers
Nick
FYI, the firmware update released today. If you check for a system update and if it's there install it you should get Netflix
