@Alpay_TR - its a known issue im afraid. Sony is aware, but i have no further information than that.
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2175704#M44073
I'm sorry if I've missed this back in the thread somewhere but my Arc audio has stopped working (it's been fine for ages). I've reset my TV and onkyo amp but still nothing.
Anyone else having a problem?
Thanks
Anis
Has everyone found lip sync to be better since the April update? I can't tell if I'm just used to the out of sync sound now!
After not hearing from since March when I was told my case about the lip sync had been escalated I've not been offered engineers to visit to repair the TV for me.
Not sure whether to bother as surely any problems are still on the software side?
I have found a way round this for me, by turning my set top box on first from standby then 30 secs later turning tv on from standby the remote still works & the sound is working:smileyhappy:
When I start recording a digital terrestrial channel and change the channel, the tv goes crazy with the HDD device detected screen popping up and closing frantically.
It shows the pop up for opening photos, videos etc on connected device and this flashes on and off.
Brand new HDD out of box and formatted for TV use. The program on the original channel records just fine though.
Does anyone have this problem?
Also - remote recording from app refuses to function - only on local network.
Hi hextablephil,
Do you mean another USB port?
Another problem is the tv sometimes says a DSAT channel does not exist. Eg Channel 31 BBC News Channel and the TV jumps to something that is in the favourites. Then when I restart the TV, the channel reappears.
Here are some issues for someone that uses Satellite tuner and have been reported to Sony since December 2015. Your reported issue is No1 :
1. Satellite Channels re-arrange themselves automatically if TV is Soft-reboot within Digital (DVB-T). Reboot from within General Sat "brings channels back" to your indexing.
2. Deleted Satellite channels re-appear themselves automatically at the end of channels list
3. General Satellite gives an error: No signal. Please check your antenna connection. This happens if in sequence:
a. Reboot from home or Digital(DVB-T)
b. TV starts in digital(DVB-T).
c. General Satellite is selected after Digital(DVB-T)
and... can be solved only if Digital is selected again and then go back to General Satellite.
4. Using Favourites lists in both Digital and General Satellite and browsing with Remote Control PROG +/- , mixes channels from these different tuners. Digital Favourites1 go by themselves to Satellite Favourites1.
5. Favourites are not numbered as 1, 2, 3 ... but keep their initial number from General Satellite list.
6. Sorting-Editing both Digital and Satellite channels does not move all channels downwards as before, but simply REVERSES(SWAPS) channels places. What I mean is if for example:
Also Quinnicus has part of your issue, also reported to Sony, here:
https://community.sony.gr/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2089574#M39396
