I am having the same problem @Batemansxxxb When I switch the TV there is no sound and the remote is not working until I unplug the TV from the mains. It happened few times. Bought the TV few weeks ago and updated the software straight away. It worked fine for a few weeks but in the last few days it started to cause the same issue. Did you manage to solve this issue? I don't want to do factory reset as I will lose all my serttings.
After few updates I decided to try to amend the channel list again and it resulted again in a wated of time, because the tv is still recovering deleted channels (adult channels and so one) and removing some of the one I want.
Can anyone tell me if the damned sony is planning to fix this bloody tv or not?
Honestly, I don't think anyone here knows I'd suggest getting in touch with them via their social channels but you'll get told to "contact support" who'll then run you through a generic listing only to go back to their social channels and be ignored
A update schedule would be a massive help to see what bugs are being squashed but don't hold your breath
Sorry if it's already been covered but I can't find the answer amongst this huge thread.
I have a KDL50W809C and have managed to navigate around the usual issues. However i have just noticed that on very dark scenes, there are patches appearing on various parts of the screen. They are not as dark as the rest of the screen and are very light and i would say almost grey.
Any advice?
@Deanfeuillade you may trying switching off Film Mode in image setting and see if the effect disappears
Cheers for the advice but turning off film mode hasn't made the issue any better. Does anybody else have the issue on dark scenes where there are patches of gray and light gray where the rest remains black?
Cheers all
@Deanfeuillade wrote:Cheers for the advice but turning off film mode hasn't made the issue any better. Does anybody else have the issue on dark scenes where there are patches of gray and light gray where the rest remains black?
Cheers all
I have exactly the same problem with KD-55X8509C. It's very annoying on dark scenes. I wonder if there is any cure for this?
