You should check something on your tv:
Done that it should work smoothly
I do have the latest firmware. If i do a factory reset will it then reset firmware?... can't be bothered right now to download/install the new firmware once more... took forever the first time.
The firmware will still be installed after a factory reset. Customised settings etc will need to be re-done however
Well i have not applied any settings beside WiFi password etc.
I would hate to say goodbye to my Sony TV as i really enjoy the picture and it's design. I own several sony products but this is a show stopper 😞
My old TV, a KDL-46EX723 was great, i guess android wasn't so good for TV's
@Kenneth_J wrote:I own several sony products but this is a show stopper 😞
Indeed so; every time I try to watch a show on it, it stops 🙂
(Only joking - since the last update (or updates - since I last used it on Jan 22, and powered it back on on Apr 24, it wanted to update itself twice, for some reason), but after that and a factory reset, it has behaved impeccably.
And the slowdown in the rate of posting here speaks volumes. So apart from waiting for YouView to be able to record, and NowTV to be added, it's all copacetic.
Excepting, that is, the entirely tragic UI. But as it was a conscious Sony decision to do it like that, I guess that is an area where we have to put up or shut up 😞
I doubt if anyone can help me but its worth a shot. Im at my wits end. I bought a KDL-55W809c in January. In March I had an issue with the remote control not responding (I HAVE A NORMAL BUTTON CONTROLLER NOT TOUCH SCREEN). I was able to get it working alright by restoring it to factory settings. The remote has alway been kinda wonky...have to raise it up sometimes to get it to register.
Last Thursday out of the blue the remote stopped responding again. THis time the ambient light started pulsing white continuously. I tried unplugging it for 3 minutes and plugging it back in. No joy. I have an app on my iphone that lets me control it through wifi so I managed to use that to again restore it back to factory settings, but unfortunately when it rebooted I was stuck at the language selection screen because the remote would not work nor the buttons on the back of the tv...nor the app because the wifi was reset on the tv as well!
I gave up on it, unplugged it from the wall and plugged all my peripherals into my old sony tv to use in the meantime (thank god I had a backup). I contacted Sony but they are of no help..just keep asking me to restore it and what firmware Im running etc...everytime I get another response via email from them its a different person (annoying). Yesterday (Sunday) for whatever reason I decided to plug it back in and try it again. The remote started working again, the light is no longer flashing. I successfully restored it and its functioning on the most part but there is still some lag in the remote. I contacted Sony Centre and they are sending out a technician on friday, but Im afraid that since its not acting up right this second they wont do anything and Ill go through the same thing again.
Can anyone give me any clue as to what would cause this to happen?? What does a pulsing white light mean? and why would the remote suddenly not work...for 3 days!!!
