I've owned the Sony KD-49X8305C for around 5 months now and I'm still getting an incredible amount of stability issues. The TV freezes multiple times a day and will frequently reset itself. Does anyone else have this level of problem? Or is it a bad set that I've got?
Well, at least it isn't just mine being a faulty set! I've been very understanding with software updates and patient with it, but nothing is happening. After any update the stability isn't any better; I've got a smaller, older Sony TV and that works perfectly. It's a bit slow in certain apps but that's due to lack of processing power.
Until about 2 weeks ago I thought I was one of a few experiencing issues with these sets too (I have a 49x8309). This was until I discovered this forum about the wealth of issues customers have, and are experiencing. I now feel "somewhat" comforted that it's not “just me”.
Since purchasing the set around 4 months ago - and very quickly recognising the fact of the set having issues from day one - I started to jot down the issues (using the time whilst I waited for the TV to reset/re-start each time (this wasn’t fun when watching TV late at night and sleepy and simply wanting a reliable TV set not just at that time)). I have a list of 36 issues, and I sent this list in a complaint letter to Sony last week (via post). I’ve not yet had a reply but since sending the letter I can 4 more issues to the list.
I am not prepared to go through any anticipated painful return discussions with Currys on this set, so I await Sony’s response (as the manufacture). Pending that, I’ll post my 40 issues on this forum.
I'm hearing LG and Samsung sets having more positive responses from those on this forum who returned their Sony 2015 set.
julianblack ha scritto:
I for one am now happy. Because of Sony I have now discovered the joys of LG.
Sent from my iPhone
What about looking at your new LG in a dark room? Its IPS panel gives you the same blacks as the Sony?
@rooobb wrote:What about looking at your new LG in a dark room? Its IPS panel gives you the same blacks as the Sony?
Do you mean regular blacks, or the ones the Sony does from time to time that flash onto the entire screen without warning?
i am sure the LG won't be putting up as many blacks as the Sony Android sets do 🙂
It's annoying because I'm really happy with the picture, there is a bit of light bleed and the blacks could be darker. But the image is excellent, especially 4K.
Surely it's just a case of software updates and optimisation? The guide for example is painfully slow loading when the TV first starts up, but surely it can be a lot faster seeing as it's just loading text from memory.
It could be an issue with Java too, considering it's Android which is built on Java. I know that Java can be really slow at first but after a little bit it becomes really quick.
