- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
2015 Bravia Android TV Issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from my iPad
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Quinnicus, yep that does seem similar. It's coming from the area at the back where the power cable connects. It definitely sounds like an actual component at fault rather than just the frame 'creaking' or anything, especially when it happens every 10 seconds exactly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
any news on the usb recording issues?
how can they get away with this??? this functionality was the main reason for buying the TV!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
TheVoice wrote:My TV (KDL-50W805C) has recently started emitting a click/tick every 10 seconds from the rear-right (with it facing towards you). It's definitely not thermal expansion, it's every 10 seconds regularly and it sounds like it's coming from a component inside.
My advice - and this is coming from a trained, qualified technician - is to turn the set off, disconnect it from the wall and call in either Sony or your retailer's support line. A switch-mode power supply making regular 'clicking' or any kind of arcing or 'fizzing' noises is really NOT a healthy thing! - It actually needs the attention of someone with real expertise to look at it to make sure it's safe to be plugged into the mains!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@julianblack wrote:
Assuming that the TV is in a stable enough state to allow you to perform a controlled restart by means of a long button press on the remote.
Sent from my iPad
Indeed so. In the case that it isn't, though, and a power cycle is the only thing that will get it back, a long press reset would always be my next step, to put the set in a known, regular state again where it only had the usual problems, and not any 'specials' that had crept in by clobbering your running state.
We really have no idea what is going on in there - even after one of these sets has returned from a software update, it can spend up to 30 minutes titivating itself further, with no indication to the user what it is doing, or when it has finished 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Let the TV fail, it could be an inherent fault that affects all their TV'S just like the Android problems.
At least if it is then they will have to recall all these crap TV's and replace them with the new Quad Core ones.
Can't believe that a mobile phone with Android works perfectly yet a TV set that is so much bigger in size can't work properly, what is wrong with Sony to produce inferior products that don't work properly or do what they promised to do?
NOT A HAPPY CUSTOMER!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Problem there is that then I'm stuck without a TV while it's being repaired or replaced! I'll speak to Sony on Monday but unless they're going to replace it with a brand new one (third time lucky?) I'll have to persuade Amazon to take it back instead.
Such a disappointment. My previous TV - a Sony KDL-40EX403 - was great (after I had the panel replaced a month into ownership). Beginning to wish I'd just kept it now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
3 times replaced plus your previous had its panel replaced and you still want a Sony?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Unhappy_43x8309_owner wrote:The search is fairly usless isn't it? Luckily google indexes the forum so you can use the 'site' option to search the thread for specific keywords. If you put the following into google it will search this thread on the keyword 'hdr' and return the reuslts in the normal fashion
site:community.sony.co.uk/t5/televisions/2015-bravia-android-tv-issues hdr
In your case : site:community.sony.co.uk/t5/televisions/2015-bravia-android-tv-issues "amazon video"
(in speech marks so it searches as a phrase) might show up something useful.
Thanks for the help on using googles index to search the forum, I really hadn't thought to use that.
Thanks
