2015 Bravia Android TV Issues
NickCo1979
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
Rush8080
Hi
is there any way I can use youview without an aerial for catchup and on demand service. As I don't have an aerial every time I try to enable youview it goes up to scanning then says no services found then returns to TVs home screen. TV is connected to internet via Ethernet with speed up to 150 Mbps.
Heckie
I agree that it is stupid because all other TVs allow you to plug in a hard drive and pause, rewind and record live TV.
I had a LG WebOS TV that I sold to get my Sony, and it worked flawlessly in this regard.
Anonymous
Not applicable
To implement encrytion on external devices, this would have to be implemented via hardware, as a software solution would hammer the processing power of the tv.  Upon saying that, when Sony implement its HDD recording, the HDD would need to be encrypted anyway, in accordace of the DBook standards set in the UK.
rdlowry
Somebody on the AvForums thread had the same issue with the on demand apps. It seems tuning some channels is a requirement. They managed to tune a couple of channels with a portable aerial and the then the apps opened fine even after the aerial was removed. Not ideal but it seems to be the only current work around.
Heckie
TBH I am perfectly happy with the new EPG.
If I miss a programme I can get it on demand, on Netflix with Unlocator, or through Kodi.
I dont see the point in recording stuff and keeping it for watching again later when it can easily be streamed if needs be - I understand some people like to - thats just my personal preference.
danielbeyzade
Most mobile processors have dedicated encryption support inside of them already. Android devices can have full device encryption on storage.
frogger38
Yes I am really upset that I bought a TV advertised to have Youview AND HDD recording. Not only did they not work when delivered I only recently found out that I can't have both when they are available.
I don't wish to record anything from on demand (via youview) just live and future TV, as I could on my 5 year old TV from another manufacturer. If they have issues with YouView authorites then they should have made this clear at point of purchase. If necessary sony should write an app which will allow recording independant of the YouView guide. Sony have messed up big time with the implementation of the facilities.
If Sony cant be trusted to avertise correctly we should bring these shortfalls to the attention of the public independantly.
It's very much like buying a car and being told that you cant use the headlights at the same time as the heater. They didn't need to tell me that I can use both concurrently, it is a reasonable assumption. And I believe this is how trading standards would see the HDD / Youview fiasco.
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
danielbeyzade
Froger38 - Email your complaint to cro.en (at) eu.sony.com (this is the CEO office)
Let's create a standard mail for people to send for this particular complaint. I would suggest the following Subject: YouView in combination with other services, not as described
Dear Sony, This complaint is from (insert name).
I and the community feel let down so we are combining our efforts together to let you know. This TV was advertised as having YouView, Satellite Tuner, HDD Recording and Dual Tuner. It now transpires that this is not possible and when YouView is enabled Satellite Tuner, HDD Recording and Dual Tuner is disabled.
This only become apparent very recently with a small disclaimer on your website. When the unit was purchased this information was not available. I ask you to either implement the features as was originally described, or offer compensation because the product is not as described. Many of us have been waiting a long time for the YouView update and are now very disappointed that this situation has become apparent.
Kind Regards (insert name)
fether
hi guys is there any way to turn updates off ??? as i dont not need or wont the youview update
regards
fether
rdlowry
Good idea. You might want to include the model number in your email. E.g. "I'm the owner of a KDL-43W755C" etc.
