SPECIAL FEATURES
Electronic Program Guide (EPG)YES
On / Off TimerYES
BRAVIA SyncYES
Picture and Picture (PAP)YES (2 size) <<<<<<<<<<<<< stated as feature working, nothing about software update, this would bepend on when you purchased your TV.
Parental ControlYES
USB PlayYES
USB HDD RecordingYES
Multiple Language Display
i-ManualYES
On-Screen Display for External InputYES
also, the other point you can add is this, *NOTE: HDD recording (REC) and Satellite features are not available if YouView functionality is enabled. this clause has only been added recently, so it's possible to say terms and conditions has changed since the item was purchase, if this was admitted prior to purchase you may never have concider the said item. Ok this maybe a grey area, but is ammunition when returning an item.
One more problem... The 65X8509C don't work with wireless display on miracast with windows 10 because of there are no drivers for it...
Does anybody know:
1. how many Gb is available inside the TV for apps?
2. what a processor serves the Android TV? Downloaded the Asphalt 8 and the graphics lags so much... So, what CPU is used in the TV?
PS Waiting for the software update that US users alredy have, at the moment it is a BIG disaster...
8Gb of storage
AIDA64.
CPU 2 cores x A17 (I could not find any 2 core A17 CPU in internet...)
CPU frequency unknown?
RAM 1,5 Gb
SSD 8 Gb
Ha-ha. I run the 3D Mark benchmark. It shows 0,5-1 FPS. This is awful. Sony, why the hell is Android needed on the TV, when it is not capable to run any games, exept of static ones? Call it Sony Android TV Sudoku Edition.
