Hi. I have discovered another fault too. If I go into the settings and set the external input, change the "TV" button to display mirroring, I can no longer access the menu, external inputs, but it loops back to the home screen again. I have the 65X8509C european set
On my X8305 the audio seems to clip every five seconds whilst watching Freeview. I'm running the TV through a Sony HTIS100. I watch mainly streaming and it doesn't affect that. Looking for a replacement this week - don't know if it will be an expensive permanent replacement or a cheapish TV so I can wait to see if the 2016 models are any better. 43 inch size fits really well in my living room.
You're lucky youre gettng any information from them at all. The people I've been dealing with know absolutely nothing and give the impression theres nothing wrong with these TVs. I see many retailers are now giving further discounts on Sony Android TVs - one is featured on todays Hotdeals emails. John Lewis are aware there have been problems but even in Currys, the sales people are still saying these are the best TVs in their showrooms. They do look good in the showrroms running 4K from a USB stick, but once in the real world of your living room, they turn into a bag of spanners. Its a disgrace.
I noticed today Currys have dropped the 55x8309 to £999 that another £250 drop in 2 weeks.
But remember Sony have assured us there's nothing wrong with these tv's, all tv's need to be rebooted daily, 5,1 sound does work, we should be greatful Sony even bothers to make this TV.
I cant believe its dropped to 999 - thats unbelievable the price drop since launch. In the space of just less than 4 months the TV has officially lost £800.00 in value from the origional 1799 price tag. I wish i had waited!
does anybody have price guarantee information or anything about how long after a sale for sony products can you claim the difference? I purchased mine direct from sony on pre order just before launch.
there is no price garrente, your left with only one option and that is to return said item, this can only be done if said item is not working correctly or faulty, say pap was not working, even though Sony advertised it as working when the item was purchased. This would be a valid reason to return the item, as it does not work as described in the sales literature. A full refund would then have to be issued. You would be free to repurchase the same item, if you desired at a greatly reduced price.
im not saying this route should be followed, but I would agree the price drop reflects customer views & reviews of a poor product
Absolutely correct. Some people on the Hotdeals site are getting excited about the huge price drop and are taking some convincing that Sony Android TVs are being reduced because they are bad news.
