I didn't try with Opera (it works with remote even if I'm not used to it), Chrome is far better and works fine with sideview mouse remote... and you can set your own home page (better since I use Chrome everywhere it gets automatically all my settings/preferred URL, etc.)
How do you get chrome on these sets?
Go to play.google.com with the same account of the TV, searhc chrome and choose to install it on the TV. Done.
EDIT: Sorry, wot he said ^^^
Easiest way that I found:
Go to G-Play on a laptop etc.
Search for Chrome
It will say 'Installed' and 'Compatible with....'
Click on 'Installed' and select the TV from the drop down list.
Bob's your relative.
Why is it just not in the app store on the TV? Thanks for the tip off peeps, can't stand that Opra! Can the app be viewable on the home screen? I can access it from settings - apps - downloads.
As previously mentioned, you need to install sideload launcher by chainfire, sideloaded apps won't appear on the main home screen.
I haven't been able to register for Playstation Now until today, but I found out how to get past the stalled sign-in screen.
1. Reboot the TV
2. Go straight to Settings>Apps>Running Apps
3. Scroll and find Playstation Now
4. Click on Clear Data and OK
5. Click on Clear Cache and OK
6. Go back to your Home screen and click on the Playstation Now app
7. You'll get to the Country/Language screen, select yours
8. Go to 'Sign in, you should now be able to load the sign in/Register screen and use your PS4 controller to navigate and enter your details
9. You get an email to your selected address to make a PSN account
I got most of the way through and decided that PSN is far too intrusive for my liking, and that I won't be using PSN at all, least of all on the TV
NB YOU CAN'T DELETE A PSN ACCOUNT once you've started the registration process, so, if you don't want to try PSN, don't go there.
BAD SONY 😞
Theres a much better app than sideload. Its called HALauncher. Its on the Google Play Store and its much more user friendly. Can install any android apps using ES File Explorer if you have showbox apk etc
