Is it possible that there will be a software upgrade so that it will be possible to do focus bracketing on this model?
Or is it only for very expensive models.
Thanks for your feedback.
I’ll try this night to update 🤞
Just updated, and all seems to be fine..
Interested the more to the general stability than the newer functions (that I don't need). Other new function (that I need) I expect from A7v 🤞
