Xperia 5 Android 10 **Bug List**
KBadOne
I wanna create this topic so we can share all the bugs found in the latest Android 10 update. I had the update installed for 3 days and was able to detect some graphical and performance glitches. If you have any issues please share it here so we can provide it to the software team.
*EDIT* 12/12 added Media Playback bug
THEME
  • The system dark mode randomly resets to light mode, had to restart the phone to enable it again without manually toggling the dark mode switch on!
COLOR
  • Super Vivid mode, randomly gets enabled after restarting the phone which ends up bricking the creator mode.
MEDIA PLAYBACK
  • Frame rate issue when playing live stream videos on multiple platforms
  • such as AT&T TV and YouTube TV. Ended up restarting the phone to fix the issue
BATTERY
  • Charging speed is slower, doesn't charge as is used to be using PD charger (will provide more info)
UI
  • Folder animation are not rendered correctly. For example, when opening and app within a folder on desktop and returning back to the desktop, the app icon replaces the folder icon for a second then defaults back to the folder view
  • App icons in app drawer randomly disapper leaving color pallete in its place (see screenshot)
app drawer missing iconsapp drawer missing icons
  • App switcher and app drawer animation are not smooth while scrolling anymore
  • The status bar does not display the correct colors in dark mode. For example, the status bar text color is white against dark background. However, in some pages the status bar switches to black colored font againts a dark background. (see screenshot)
status bar inverted colorstatus bar inverted color
0 REPLIES 0
