In my Xperia 5 I am unable to use the tele lens.
The normal lens works fine, camera switches fine to wide (w), but pressing (2) just zooms the normal lens.
Any ideas how do I fix this?
I had the same issue as well but the customer support pointed out that the Tele lens is activated only when the light conditions are good.
