How to complete setup?
MaxaP
I have this notify in task bar to "finish/complete setup". When i press this button to do so - nothing happens. When i doubleclick - notify disappear, nothing happens and notify comes back in 5 minutes. I don't know which setup i didn't finished. And i i really don't like to go through all the stuff from beginning again third time. Why this button doesn't leade to finish setup?
5 REPLIES 5
profile.country.RO.title
_alexdon_
@MaxaP  care to post a screenshot of the screen and what happens when you press on it?
alexdon
MaxaP
So first one how it looks usualy all the time, second one is when i press "continue" - it disappear without any popping-up-windows, and in while the notify will be back.
_alexdon_
@MaxaP  difficult to understand as its russian probably, but did you try a simple restart of your phone?
alexdon
MaxaP
Yes, restarted many times
profile.country.NL.title
Strampke
I suggest that you do a reset.
You haven't set it up completely so I guess it will do no harm to reset.
(Take care that you do sync with Google to be shure)
In settings find reset and go for it. (battery >80% charged)
