Hi im using this phone since release few weeks ago and i have some Bugs which i wanna tell you. I didn't have these problems with a previous mid-range smartphone.
I sometimes experience brief interruptions when streaming. I watch 20-30 Reels, and then sometimes the loading time is 10 seconds. When listening to music, it also happens that I sometimes don't hear anything for two seconds. The same thing happens in group chats, while shopping, etc. So I think it has something to do with the internet connection. At home, however, everything works perfectly fine with other devices.
At home im connected to 5ghz wlan.
The Discord App doesnt show me some channels/forums/chats. If im clicking on it, i only see black screen. Then i reinstalled the app, all was fine, another day same problem again.
If I want to photograph a bottle on a table, whether outside or inside, regardless of the light, I focus on the bottle, but after WhatsApp saves the image, the focus is on the background and the bottle is out of focus.
Whats wrong? xD
edit: i will switch to 2,4ghz wlan now.
Regarding the out-of-focus photo.
It happens to me too, if you take the photo from WhatsApp.
I've discovered that without focusing, the photo comes out sharp.
Thats not really right. When you taking a picture and the bottle is sharp, after you taking the picture the backround is sharp. Otherwise when you taking a picture from the botther 5cm before the Camera... thats fail
and, the phone has troubles with 5ghz wlan from my big fritzbox 6591 cable. its not an old fritzbox, so whats the Problem then?
i have loading times in reels, and connections cuts in music streaming.
It's true, what you're saying. I was more inclined to believe that the WhatsApp app isn't well-developed for this device's camera. If you use the phone app, you're fine.
And the lag or delays on Wi-Fi or 5G networks, I can tell you from experience: I also had the same problem with an iPhone 13 Pro. For browsing, I've found that Opera is a better browser than Chrome, both in terms of loading times and speed.
Its not browsing, Its on music streaming, its on youtube reels, insta reels....
Does anyone here have these problems that triggered the sales freeze?
