Hi there.
Does anyone know how to delete empty Cinema Pro project folders from the Album? Currently, I can only delete the contents, but not the folder that contained the clips. I've now got 25 folders I can't get rid of!
Open the Files app, and if you use an SD card, pick that one from the list, and look for the location of the folders, and if you use the phone storage, then open Files app, and pick J8110 and look for the folders location, and just long press and delete them.
Fantastic, thank you!
