Cinema pro app
RÉSOLU
Torqueshop
Visiteur
Cinema pro app
I can't change the frame rate or the look in cinema pro app, any ideas??
1 SOLUTION APPROUVÉE
Solutions approuvées
DJAxcess
Visiteur
Resolution and framerate can be changed by starting a new project in the top right.
Once you started recording something within this project, resolution and fps are locked.
Voir la solution dans l'envoi d'origine
2 RÉPONSES 2
DJAxcess
Visiteur
Torqueshop
Visiteur
Thanks for the reply, all sorted now, can't believe how frustrating that was! Didn't realise it was locked to a project😁
