How can I change the resolution to maximum 23mp? I can't seem to do this Thanks everyone.
Hi @747400, let me see if I can help out here.
The available still image sizes in Xperia 1 is 4:3 (12MP), 16:9 (9MP) and 1:1 (9MP). I am afraid that there is no option enabling you to have 23MP. In order to change the still image size, open the camera app > Tap the cogwheel in the top right corner > Tap Still image size.
I hope that helped!
I hope that helped!
Thanks so my XA 1 has a higher resolution than this model đ˛
