Does WALKMAN on Xperia Z1 have a sleep timer setting? If so, how to activate that feature?
Thank you!
Thanks for the response, you can try Poweramp if you want a sleep timer feature... comes in handy listening to music at night...
Thanx for the info, I'll check it out
I think you can use Smart Connect app. Create an event there, Then add condition, Choose "TIME". Then set the time when you want to sleep Walkman app (TIP: Since it will be asking "between" what time, set the time, and 1 minute after...). Add start action, Click "Play Tracks", Choose "Pause".
I hope it helps. This is always my setting in favor of the Walkman app over Poweramp.
Thats a great suggestion
