My speaker sound just is not working, no sound on phone call, music apps, facebook nothing until I reset my phone the sound is back on! It stays on for a few days then goes back off and I have to keep resetting my phone before making any calls I think this is a software but how to fix it without going back to factory settings, I have used my Bluetooth headset and it works fine but the problem remains after I disconnect my headphone device! Phone is an expira z5 compact
I have exactly the same problem .
Only started early March .
Seems like software .
I have lost all sounds from typing dialling and sound during a call.
Xperia z5 premium
What did you do to solve the problem, did if fix with an update or are you still having the same problem?
Hello @MathewB;
Try to use your phone in Safe Mode to see if the problem remains, if not, it is a third party app that is causing the problem.
If the problem remains the next solution is really performing a software repair with Xperia Companion.
Anyone know how to fix we can not hear when call in
yea same thing here no sound from speakers or headset , cant figure out whats causing it , happens totally randomly and all works fine after restart sometimes its fine for days.
