keyboard typing problems.
Tonyblue
Hi I've been having problems with the keypad/board on my xperia z3. It's become vague when typing as If my fingers have doubled in size and the wrong letters are coming up. Such as press the U key and I'll get either Y or I. The W key has simply ceased to work at all now.
I've read the articles where it says go into settings, select apps and then all, thats where I come a cropper. I don't have the all bar.
Where do I go from here? Many thanks.
35 REPLIES 35
Piotrek2
I've got exactly the same problem.
The phone is in great condition, I've used Case-Mate hard case and dedicated glass. The screen isn't broken or even scratched.
I've used many phones made by other producers and never had a problem like that. When new, it was one of the most expensive phones on the market...
Sony how can you help?
Best regards,
Piotrek.
ivipivi
I'm having the exact same problem with my Z3 from yesterday.
Sony, can you resolve this? Sooo annoying!!!
Sylvia3
I am jhaving the same priobnlrem qwiyh my keyboard. It's as if it's super sensitive re and there aitocorrtwect has gone hayqwierwe.
I nwrwrred a fix!!
Also can't ssdo sumbols such as reexclasmation. Point from main keyboard.
I have left words unchanged so you you can see the problem.
Wilmaschra
Here type problems too.
Simon1969
Hi jake - I have this problenm too. Ran the test and there is a thin area (2 mm) along edge of screen lower right side which does not pass - which is why I cannot type 'p' easily (unless I turn on side - but then the delete key doers not work). its not completely lost -but very hit and miss from hour to hour whether i can use the keys at the very edge of screen. Do I take it back to the shop? (Currys UK)
Rahdo
This has just started happening with our Z3 as well. I don't think it's a software problem because
1) only the H and B key are affected by the issue
2) if i rotate the phone to landscape, all they keys are fine
So that implies there's something wrong with the touchscreen itself at the spot where the H and B keys are in portrait, no?  Maybe not, because on the numbers/symbols keyboard, all the keys work fine, even the ones in the same spots as the H and B.
I've tried running in safe mode, and uninstalling the keyboard software updates, but it's still a real problem, and has made the phone practically unusable for texts. I really hope Sony has a solution for this!
arrgggh
Same problem on my z3 in portrait mode, letters h and b effected, clearly a phone problem rather than softwhere. What are you doing about this sony?
Swiv1
I have the same problem..
It seems to have happened quite recently and only affects the 'W' key.
I've marked the region of the screen where the 'W' sits.. I rotate the phone to get 'W' to work, however the screen responds in other apps where the 'W' sits in portrate mode..
I think this has to be a software issue..
Alexa92
Hi!
Could anyone solve this problem? Really annoying..
Many thanks.
Porti_ec
Samw here, any solution yrt?
