keyboard typing problems.
Tonyblue
Hi I've been having problems with the keypad/board on my xperia z3. It's become vague when typing as If my fingers have doubled in size and the wrong letters are coming up. Such as press the U key and I'll get either Y or I. The W key has simply ceased to work at all now.
I've read the articles where it says go into settings, select apps and then all, thats where I come a cropper. I don't have the all bar.
Where do I go from here? Many thanks.
35 REPLIES 35
AndyNZ
Where's the Sony 'expert'? Duck and cover eh?  Well I've had the same problem for two years on an unblemished phone .
Webzmzzcvc we need a solution .can't delete that stuff ad as keyboard not working properly.  This is bs
Euralio
I cannot believe It. Where is the tech support or bug fix for this?
pastrumi
my wife has the z3 compact and is having the same problem with letters/part of her screen not working - did anyone find an answer? is a factory reset needed - will this resolve it?clearing app data and changing the keyboard does nothing.
lokodo
No solutions from Sony.
The problem is the bad quality glue used to fix display on the motherboard.
Yes, Sony know display issue, Sony know our post, discussion, forum but Sony can't reply because the problem is an embarrassing factory project error.
The glue is thermal sensible and disconnect all flat cables.
Knowed problems:
Proximity sensor
Front camera
Left edge display
Down edge display
Right edge display
If you are able and skilled you can fix try opening case with thermal gun and then replacing all adhesive strings and flat cable.
You had spent 400 € or dollars for a BUGGED phone and SILENCE FROM SONY.
Kriss12041981
Please check whether your phone is in the "glove" mode and disable it. The typing problem will then be solved.
Paddy4474
Hi when I press keyboard it double or ttripllee press like iin this mmeeassgge
