You can't change the bands, perhaps you rooted and/or unlocked the bootloader and did something else?
Hi,
I have done the same
See
/t5/Xperia-Z1-Compact/WARNING-Never-Change-Radio-Band/td-p/905055
You need te reset the phone (will loos all data if not backed up)
Please tell me complete procedure how can i get my signals back i accidently changed the radio band to US please help.
By downloading an app called hidden settings\you see an icon which calls select band mode you can manually change it
