Hi Ywjong,
Welcome to the community,
You should try clearing the app to default.
Menu > Settings > Apps > All > Messaging > Clear Defaults
Let us know if this helps.
Hi Ywjong,
That's great news, glad I could help out
Hey sony, i have done the steps to send short codes but it still doesnt work i tried putting the sim in another phone and send the short code it still doesnt work is it the phone or the sim? help pls
Hi,
I also did the same process as mentioned above, but still not able to send SMS to a premium number. What else can we do to fix this? Thank you in advance for your help.
Go to setting > app > tap the 3point on your right top of your mobile phone > selext sms premium access > change never allow to allow
Hope this will help,
I've followed the previous advice and still can't send texts to 5 digit numbers from my XperiaS
Sir but this option is available in mobile honor 6x. Now what I do?
