homescreen wallpaper problem
SOLVED
AspireAnakorn
I'm using xperia z and i have some problem with the homescreen. I use xperia wallpaper as the wallpaper but at the edge it was black(only background wallpaper),when using another app the device screen is normally. how can i fix this
1 ACCEPTED SOLUTION
coolasrevi
Contributor
You can try once repairing your phone with PCC. Coz even when i am on 7 home screen it doesnt come black like that.
9 REPLIES 9
coolasrevi
Contributor
could you provide screenshot or something cant really get what you meant
AspireAnakorn
Sry i forgot to post it
https://db.tt/xj7l4JwY
coolasrevi
Contributor
K  Clear data of wallpaper picker, it usally works,
AspireAnakorn
Hmmm i cant find it
AspireAnakorn
Did you mean live wallpaper picker, i had clear it there nothing happen.
coolasrevi
Contributor
I Mean Xperia Wallpapers, which is found in all apps tab
AspireAnakorn
Thank for the answer,but that not help
coolasrevi
Contributor
gitzz
i also faced this problem when i was using dodol wallpaper maker.or some other wallpaper making application.
After removing these wallpaper making apps and restarting. phone solved my problem.
on Xperia ZR!
