Google apps problem (Play, Wear Os, Fit) on Xperia Z5 Dual
Goran1
Last couple of monts I have a problem wih some Google apps: Google Play, Google Wear OS and Google Fit. I have tried so many things and so many times: from clearing cashe and reinstaling mentioned apps, to reseting phone couple of times. None of this solved the problem.
Main issue is with Google Play: I have to uninstall update of this app and than install updates for all apps in my phone. I cleared cashe several times and tried to reinstall app but nothing changed. I also receive fake information that I had to uprade Google, Google Wear OS and Gogle Fit and that updates dissapear after I uninstall update of Google Play.
Other app, Google Wear OS is also with some bug or problem…I don’t know what. Anyhow, I had to reset my SmartWatch 3 several times to be able to connect it with the phone.
And finally Google Fit. Few days works fine but after that and after update of that app, appear 3 or 4 Fit icons in my phone which are unusable and I have to uninstall that app, uninstall update in Google Play an install again Google Fit.
Maybe I should mention that I also have SmartBand 2 and I also planning to get Google Home device and I hope I will not have additional headace.
Does anyone have similar problem or any solution for all of this?
Many thanks in advance for any kind of help.
Goran
In addition to my problem with Google Apps:
-today I had a problem with Google App…after installation of update I lost green Google icon i Settings (Account & Services) and part of setting where I can manage Trusted devices at Lock screen & security, also dissapear. That already happened before and this problem is solved after phone reset. I am out of idea what to do, what to try.
23.07.19.
Again same problem Worried_Face : lost Google green icon and Smart Lock in Settings; I had to reset SmartWatch as well. I tried to uninstall all updates from every Google apps in phone and I made total mess with my account which took me a great deal of time to get back settings as they was. After that I used Xperia Transfer app (after phone restart I somehow get an option to restore settings from this app) and after phone restore I got back those icons from above.
Does anyone know how can I get help from Google staff…it seems that the main problem is with my account and some settings which is unknown to me.
1 REPLY 1
Ems85
I have the exact same problem with Google Play! Seems like a common problem but noone seem to know how to fix it... I just e-mailed Sony about this and hope they can give me an answer thats worth something. Otherwise I'm affraid the only solution is a new phone! Face_with_Steam_from_Nose
