- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello there,
each time I try to do a backup by Sony companion or directly from the phone it stops suddenly.
When I do it from the phone with backup on SD card, all files stopped at 50%, not 50.2 or 50.9,all files are at 50% and nothing happen after.
if someone can help.:smileygeek:
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hello Body,
thx a lot I've done that then iworks once and then I've done complete backup and it worked also perfectly...don't understand why but ... thanks!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hello
'@uliwooly
thank you for your answer, yess using companion at first tries and it was not working then used directly the backup form the phone and done also with safe mode... same thing it blocks
Thx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just to clarify, PC Companion or Xperia Companion?
Are you trying to backup apps and photos and videos? if you are, uncheck them and see if it works.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi baddaddy,
When you go through the backup are you backing up all the content or only some categories, and if you are doing all of them can you please try deselecting some categories.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
Good day..
Did u get solution?
I also stuck at 50%.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
HI Jake,
Good day to you mate.
I only update one still the same stop at 50%.
In addition, I could not edit my back up files too it's stuck at signing in account.
I have flash latest software and I locked back my bootloader.
But I lost Drm keys. Is it cos of Drm keys?
Anyway all the rest applications was run with no issues at all.
I really need it to be done as fast as I can.
Pls kindly advise. Looking forward to hearing from you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey,
How did you solve the problem?
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
